LSPV Adjustment Help Needed...
Mukilteo
I recently installed OME 2.5" lift (850/860), Slee's caster correction bushings, and at the same time adjusted the LSPV body down .25" per the thread provided in the FAQs. Last Saturday I was driving on the freeway with my 2 girls (2 & 4 years old) and the car in front of me slammed on their brakes and I had to as well. The rear end felt very squirrely and unstable, but managed to stop in time thank God. :eek:
I've researched the LSPV threads and I am hoping someone can confirm whether my assumptions are correct or not:
- The squirrely rear end under hard braking is an indication of too much brake in the rear vs the front - over adjusted the LSPV?
- To solve this problem I need more of the braking force applied to the front brakes
- To do this I need to raise the LSPV body slightly, still below the original stock location, but higher than the .25" I have it lowered to
I might be totally off base here.
One thing to note I was previously running the stock OME lift (861/862) and didn't make any LSPV adjustments and the braking seemed unchanged with the inch of lift.
Thanks for the help.
Russell
did you have additional weight in your back . ?
Did you have abs .?
did your rear was blocked first than your front tires . ?
There was no additional weight in the back other than 2 kids in the 2nd row and empty third row seats. The vehicle does have ABS. The tires never locked up, but it sure felt unstable in the rear.
.............The vehicle does have ABS. The tires never locked up, but it sure felt unstable in the rear.
Just trying to understand what you mean by "squirlley" or "unstable". If the tires didn't lock up, I'm not sure if I understand. If you have access to a dirt or gravel road and a helper, try this:
Find a straight section where you won't bind up your drive train. By your sig line, looks like you got the CDL switch. Have your helper watch your front and rear wheels from a safe distance, out side the rig. Engage your CDL to turn ABS off. Get your speed up to about 20 MPH and panic stop (lock up your brakes). Instruct your helper to watch and see which end locks up first or if at all. Ideally you want front to lock up first, but you also want the rears to lock up, too, but not before the fronts. Weight in the rig is not a factor since the LSPV auto adjusts for that anyway. You can tweak your adjustment to get the desired results. It may take several runs to accurately observe brake performance. Have your helper drive and you watch for a while. Also unlock your CDL when you're turning around and when you're through. Let us know how this turns out.
