LSPV adjustment = good
Utah
I just brought the awesome back to my brakes.
After I put 30mm MAF spacers in a few weeks ago, I noticed that my brakes weren't quite working up to par. Granted, it wasn't much of a lift, but the fact still remains. I've had a few close calls lately...
I moved the LSPV down about 1/8", and WOW what a difference!!!
Just had to share. :D
-Lane
IMHO on the 91/92's with drums, total LSPV system removal is the best option yet. Shoe life isn't decreased that much, pedal feel is way better, and it just damn stops better than I could ever get it to with a million different adjustments of the LSPV (which all were good improvements)
Slick mud, wet roads, etc...no squirrelly rear end issues even with very spirited 19 y/o driving.
how do you adjust the bias if you do remove the LSPV?
You don't... I would assume that's why it's not recommended.
I'm not taking mine off any time soon.
Drum brakes are better for holding then they are for stopping. You would be hard pressed to get into a situation where the rear drums will be gripping more than the front disks.
With rear disks it's fairly easy to adjust the LSPV to the point where the rears grip more than the front (even more so by removing it). This is (or can be) dangerous.
*IF* I had rear drums I'd have no qualms about removing the LSPV. But Mr. T put it there for a reason (safety) and so I would not recommend anyone remove it without doing their own research first, and understanding exactly what they're doing.
Well said Ebag, I wouldn't advise it nor recommend it for rear discs....other than over powering the fronts and being a safety issue it's just not needed. With the rear drums you just don't know brakes until you really mess with your brakes and atleast drive one without a rear LSPV. Mr T. is a smart man, but he still didn't perfect everything on the LC80....if he had EVERYONE would drive it.
I don't remember the LSPV setup too much, so how would one go about removing it? And if I did remove it would it be easy to re-install if I didn't like the setup without it?
You simply replace the LSPV with a T fitting. Pretty easy to go either way, as long as you're not dealing with rusted/broken bolts or such.
i hate the drums, ive had mushy brakes since ive owned this LC
LSPV adjustment on my 92
Wow, I have brakes. Just adjusted mine down about 1/4" on my 92 and can't believe what a difference it made. I've tried everything from extended stainless brake lines, synthetic fluid flush and OEM pads and shoes and this finally made the big difference. Thanks Lka1988. :clap:
