LSPV Absolutely necessary?
Rosamond Ca.
Just as the title says. Is the LSPV 100% necessary? I have seen it removed from mini trucks before with no noticeable difference. I was just wondering how removing it may effect an 80 series, especially when lifts and tires are involved.
If removed, I would install a manually adjusting proportioning valve in its place. Otherwise you may end up with the brakes having too much bias to the rear.
I've been planning on doing this for a long time, just never gotten around to it.
Thanks.
After I posted the question I got un-lazy and searched the subject. Found a wealth of knowledge on the reasons to keep it, and properly adjust it after a lift. I thought I may bypass unforeseen headaches by removing it. Looks like it will just cause more.
This site is simply amazing though. In searching on the LSVP question I stumbled into another bit of info I was curious about. I found the percentage to add to my Odometer to compensate for bigger tire size (285's).
