I had to order a new lower oil pan for my 93 FZJ because the threads on the current oil pan are stripped. I looked but could not find a gasket for the lower section of the oil pan. Does anyone make one or should I just use some RTV?
Is there a Toyota RTV I can use lolToyota FIPG(form in place gasket) #103 also known as rtv.
You are saying your lower oil pan the black one the drain plug hole is stripped? Or the upper big long aluminum oil pan holes are stripped for the lower pan bolts to go into?I had to order a new lower oil pan for my 93 FZJ because the threads on the current oil pan are stripped. I looked but could not find a gasket for the lower section of the oil pan. Does anyone make one or should I just use some RTV?
