I was under the cruiser a couple weeks ago and saw I had an outer tie rod end with a torn boot. I looked at it again today and found grease leaking from the lower control arm ball joint and a crusty upper front bushing. The stabilizer link bushings are also toast (I can't believe these are more than the tie rod ends). From what I can find here on mud and given the fact that I plan to do this in the driveway with basic tools, it looks like the best option is a full lower control arm replacement. I'm guessing I should try to get it done now before winter. It drives straight with no clunks or noises. Any experience with this project? Any other parts I should check before I order or proactively replace while I have it apart? I'm sure it will need aligned. Any tips to get it close so I can drive it 15 miles to the shop? Thanks for the community help.
