Low / rough idle...continued
Los Angeles
This question is related to this thread:
https://forum.ih8mud.com/showthread.php?t=61744&highlight=wiring+harness+fix&page=3
So, the low idle I experience seems to only happen when the fan is turned on through the center consul. The a/c, normal, and heater all seem to have the same effect. Anyone have any ideas?
Second question is how do I test the wiring in the harness where it goes behind the EGR? I know people have found bad wires back there and repaired them, but how do I find out which are bad if they arent visually damaged on the outside? I have the FSM, but couldnt find this. Maybe I'm not looking in the right section??
Brad
Howdy! Tighten up or replace the fan belt that runs your alternator. It is probably doing a low-speed vibration whenever you add more electrical load to the system. Could also be a bearing starting to go bad in the alternator. John
