Low Range Torque Wrench
Panamá
Website
www.4x4panama.com
I already have 1/2 needle one and 3/8 click style ( craftman & husky ) but I'm looking for a really small one, something to use in my hubs ..
Dunno what happen to me but I'm used to break those bolts, and I'm using 1/4 small ratchet .. well at the end I need one for those bolts .. at the hubs .. coz I have big problems measuring by hand the right torque of those and obiusly I can't do the job with the bigger wrenches .. ( thought it will be worse ) so I'm looking for advices about low range torque wrench ..
thanks !
David
Harbor Freight sells a 1/4" drive that measures in inch pounds. Not the best tools on the planet but I've found them to be okay for stuff like this that gets used occasionally by a shade tree mechanic.
I don't need NASA stuff .. just something that knock my head right before I start breaking bolts .. ( and then start looking for extractor and loose more hours extracting the bolt )
did you have a part number ?
Hello Allan .. I don't have access to the link ?
Access Denied
You don't have permission to access "http://www.sears.com/shc/s/p_10153_12605_SPM214238581P?" on this server.
Reference #18.23491f45.1300156134.1fc89a0
I don't have any experience with HF torque wrenches, but to me the low range torque is where precision matters. Personally I would spend a bit more for a torque wrench especially the lower range ones...
I already have a good Proto one .. what I'm looking for it's one 1/4 handy to use in my hubs .. I'm a champ breaking those bolts ..
since hub cap use 7ft-lb and hub body use 24ft-lb it looks like I'm looking for 5 - 50 ft-lb range ..
Or a 25 to 300 in-pound range.
I'm looking for that one .. since hub cap bolts are like 84 in-pound and hub body are 288 in-pound
or a 2.824620726-33.895448707 newton meters :D i am very happy with my craftsman 1/4 click type in inch lbs
the most I've found are ft pound and are 5 - 75 or 5 - 80 ..
I have just no luck with any 50 - 300 in pounds ..
I have a 5 - 75 ft lb 3/8 drive that I get a lot of use out of. Buy a used quality tool and have it calibrated.
how it performs close to the min range .. said 7 ft/lb . ?
