Low or high pinion diffs
australia
G'day guys I'm part way into a ford nine inch mod to make a six wheel drive (extending pinion through the center and out the back) to drive a second diff, We use a nine inch because the pinion is low enough to clear the internals. I'm keen to see if there is any other diffs that can be used so if you know another diff that can be used some info on them would be grate thanks
You might want to head over to the hardcore and ask that question. Much better luck with something custom like this over there.
HardCore Corner - https://forum.ih8mud.com/forums/hardcore-corner.19/
Sounds like a sweet setup.
