Hello, I had a question you guys might be able answer. I recently rebuilt my 1970 F engine, i have since put on 1100miles with the break in oil. When i rebuilt the engine I made sure to use assembly lube on everything, and I also pressured up the oil system by using a drill with a rod that fit into the oil pump like the distributor would. Up until 1000 miles the oil was as clean as it was when i first put it in. However today i noticed that when the engine heated up to about 190 degrees the oil pressure dropped down to somwhere between 5-10 psi. Within the last 100 miles my oil has gotten dirty so i figured i would change my oil, i also thought something might have clogged the small oil line running to my gauge. Also my line running to the gauge has big air bubbles running through it, it always has and ran fine, however, i thought it might have gotten more hence the low oil pressure reading. My plan was to change the oil, then disconect the oil pressure line from the gauge and start the engine letting the oil be forced out the oil pressure gauge line then reconnecting it to the gauge. Any help or suggestions would be appreciated.
