Dear Members,
I'm quite new to this site and forum, though i've been following posts since i bought a 80series early last year.
A brief history.. I've been on the hunt for a diesel 80 series for quite a while and came across one last year and bought it. It 's a 1997 HDJ81 JDM export, mostly stock. Winch Bullbar, BOSCH Halogens, 33" BFG AT TA KO's, Factory lockers, FR and RR. No CDL Switch, Full Time 4WD. Polybush all round, Monroe Shocks, King Springs. Its got a 1HD-FT and A442F tranny.
I've been reading about Big End Bearings on these engines and have seen a lot of posts on 1HD-T's but not many on 1HD-FT's. I'm a bit concerned on oil pressure and a slight knocking sound, almost like a diesel knock.
The oil pressure is fine when it's cold, ie the needle is well above the high mark at idle. When the oil gets warm, the needle drops to almost between the first 2 marks on the gauge. I'm using 15W40 Shell Oil and am in the equator region in Kenya, East Africa. Ambient temperatures are around 30Deg C.
I've checked the valve clearances, a real pain, but got there after 3 hours under the under. It doesn't spit out a single drop of oil out of the filler when running.
I bought it with tempered milage so am not sure what its clocked, but i'm guessing around 300k Kilometers.
Please advise if the Big Ends could be causing the oil pressure to drop, or could it be the oil pump?
Are there any other tests to narrow down to the culprit?
Would appreciate some feedback from the abundance of knowledge in this forum.
Thanks,
Thanks,
