Low oil pressure Need help!!
Rolling Meadows, IL 60008
Hello:
I recently purchased 1996 LC and everything works fine except for oil pressure gauge. The engine works very smoothly and idle RPS are about 650 which is good. We checked oil level - good. I know that previous owner recently replaced valve cover gasket to fix major oil leak. He also told me that this truck takes about a 1 qtr of oil every 800 miles. The oil gauge moves just slightly when I speed up but not much. I also have 1993 LC and when I compare both gauges the one in 1996 looks dead. Has anybody been challenged with the same issue? Thank you very much for your help. :cheers:
I'd put a manual pressure gauge in place of the electric gauge and see what readings is shows. Low oil pressure is a symptom of failing rod or main bearings but I wouldn't draw that conclusion before getting a solid manual gauge reading on the oil pressure.
Mine does the same thing, but the mechanical gauge verifies that I am indeed running good oil pressure. I've changed the sender, but it didn't help. Verify pressure with the mech gauge first.
Tony
I never figured out where these gauges are supposed to read anyways. Anyone know the "normal" for the 3FE?
Assuming your using the same grade oil as on the '96, then you should do as pointed out above. The part is a cheap one to replace if that is what has failed.
Mine did the say thing when I first bought it. The PO was religious about changing the oil and I have the receipts. However, he used the Fram filters and cheap 5W-30. I switched to a Toyota filter and Mobil 1 0W-40 (Summer) and 0W-30 (Winter) I no longer have this issue! It does still use oil but that is common for this motor I understand. Also, others like different oils, this just a matter of personal preference. I have always had good luck with Mobil 1...
