Sorry didn’t read the whole post, disregard my ignorance.Maybe it’s low on oil![]()
Thank you. I’ll give it a lookThe sensor is located on the lower drivers side of the engine. Clean up the electrical connections and see if it makes a difference. Sensor is easy to remove and i am sure a test is fairly straightforward. Its a bit spendy if you need a replacement.
So what is normal oil pressure gauge reading? I just had the sensor replaced and when he engine is warm, the gauge goes to about 10 at idle, then when I accelerate moves on up to 45-50 range. At 75 accelerating it at 55ish. Is that normal?I have a 95 FJ80 with 260,000 miles. I’ve owned it for 22 years and love the truck. The low oil indicator intermittently started coming on. Oil pressure gauge is normal and oil level is full. Is it common for the sensors to fail?
