i just noticed this morning, when i first started it, every thing is fine. later on when the engine is hot, the oil pressure gauge shows almost all the way to the left(lowest), if i step on the gas, the pressure will clambing up to normal at 2500rpm.
a little more info on the 4Runner, 129k miles, 4wd 5spd, gasket recall was done in april '99(50k miles), oil change 800 miles ago with 10-30 oil and Toyota oil filter at dealer. bearly noticeable rod knock. water temp is fine, idle is flat at 600rpm.
i did a quick forum search before i post, but got mixed results. it can be as easy as replacing the pickup screen to pull the head.
is there any thing i can do before i sent it to the shop?
thanks.
thanks.
