Well I had my truck in the shop and had my mechanic go ahead and replace several things.
Symptoms: Idle around 500- 550 when warm VERY annoying
BAD Throttle cable: I had this for several years as it stuck at takeoff.
Solution: Replace the bad throttle cable AND install new PCV Valve, Grommet and tube.
RESULTS: Smoother acceleration with slick new cable and idle at 625 when warm...FINALLY.
I tried cleaning the throttle cable, cleaning the IAC, looked for vacuum leaks,
Cleaned the butterfly, Redline injector cleaner and nothing worked.
Apparently the little spring in the PCV valve gets old and may stick. Replacing it did the trick. Your results may vary...
airlaird
airlaird
