Low idle after HG replacement
Orygun
Hey Folks:
I've been driving my rig now for a week after doing the HG replacement. Even though everything seems fine (I check my overflow reservoir every day for little bubbles) I'm still in paranoid mode.
I have two questions now after this project:
1. My idle seems a bit lower than prior to the job (no lower than 550-600). While driving I can detect no difference. The throttle cables, although taped when I did the job, seem a bit loose during idle. Should I tighten these or look for another cause (intake hose, IAC, etc)?
2. Before I start in the morning my overflow is right at the "full" level. When I start and let it run for a bit the level is about two inches above "full". Does this sound right?
Cheers,
IIRC, the idle is supposed to be ~625 RPMs when warmed up and A/C off.
-B-
Thanks Landtank.
The idle issue is while in park at idle, and it occasionally gets low enough that I get a little vibration. One little tidbit--I had to replace my VAFM with one from a 94. Could this be the issue?
Thanks Landtank.
I don't think so but I'm more familiar with a MAF system.
Have you taken the time to set your timing with a light? This can cause a low idle if it's off a little.
