Low cold idle?
Austin, TX
Been having this issue with my FZJ where it will idle really low (~400RPM) before it's warmed up completely when in drive. This doesn't happen at startup, it starts and idles down to ~800RPM fairly quickly in park. This happens when you drive down the street to your first stop sign/light, it idles so low it almost wants to die on you. After it gets up to operating temp it idles completely fine, doesn't seem to make a difference whether the AC is on or not (other than really dipping when the compressor kicks on).
Ideas?
Tucker
BTW: New cap/rotor/wires/plugs with PCV/hoses about a year ago (before this started), intake hose has been replaced ...
Ever find a solution? I have the exact same problem with a 3fe motor.
