SOLD Louisiana : 2004 GX470 - radflo, metal-tech, scs
Status
Not open for further replies.
Louisiana
2004 GX470
218k miles
75k miles on engine
Replaced at 215k miles:
Engine from LKQ with 72k miles
Timing belt & Water pump
Idler & tensioner
OEM Radiator
Front diff fluid
t-case fluid
rear diff fluid
transmission fluid + filter
High angle inner cv boots
Axle seals
OEM Toyota front lower control arms
OEM air filter
Modifications also done at 215k miles:
Radflo 2.5” front extended travel coilovers
SPC Adjustable upper control arms
Radflo 2.5” long travel rear shocks
Metal-tech rear long travel coils
Metal-tech adjustable rear upper links
Metal-tech adjustable rear lower links
Metal-tech 3” bump stop drops
Metal-tech extended rear brake lines
17x9 -38mm Stealth Custom Series F5
285/70 Cooper Discover STMAXX
History:
I bought the GX with a blown headgasket in 2018. It had 6 previous owners. The 6 owners initially scared me, but my intended usage for the vehicle was off-roading with modifications and a full update on maintenance, so I knew whatever wasn’t done, will be done by me. The dash has been replaced under warranty as well. I own a mechanic shop, so all maintenance work was done by my shop. First thing I did was took the heads off, and had them inspected. They were way out of spec; therefore, I went ahead and purchased a used motor with 71k miles on it. I did the timing belt and water pump, installed the motor, and she started right up. At the same time, we did all the maintenance and modifications listed above. Since then, the vehicle has been great. She’s been on a couple overland trips and has never let me down.
Price: $12,000 OBO
I have all receipts, a carfax from before I bought it, and lexus history saved on PDF, so just PM me if you would like copies of those.
Status
