Loud screeching noise in reverse
Reno
I am having an issue with a loud screeching noise in reverse with no movement in reverse. Seems like it is slipping. Seems to only do this when it is at full operating temps. I pulled the camp trailer yesterday and seems to be severly lacking in power thought I had maybe heard the noise pulling a fairly large hill. After I parked the trailer and backing out of the driveway it made the sound, had some one help and listen underneath and was told it sounded like it was coming from the transfer case and no drive shaft movement at all. Is there a clutch in the xfer case or does this sound like a transmission issue? I will be taking in to the shop just looking to see if any one else has come across this before.
Dosent seem to rev at high rpm's and seems to run fine forward, and this is not a constant problem.
this is a 1997 LC
Recently changed fluid about 2 months ago and did it again recentlly about 2 weeks ago
182,000 miles
Thanks,
Jeff
it would sure be nice if you guys can post the links to this stuff. Search here brings up way to much stuff to sort through for us newbies to the 80 series. The FAQ is full of dead links. I have spent several days there trying to look this stuff up from past posts.
Not trying to start up any drama, just pointing it out, as I am NOT a newbie to off road or the mini truck forum, but a newbie to the 80 series and this part of the board.
The TSB is in the second page of the link above. Here's a summary lifted from previous threads:
TSB breakdown:
Starting with serial number 96JE-06161, the B3 brake return spring assembly and low coast modulator valve compression spring was updated.
Starting with 97AE-07106 the material of 3 O-rings where changed to help them seal better.
Then serial numbers 97H*-00001 thru 97K*-99999 need to have the check ball added to the valve body.
Look at your serial number and plug it into the serial ranges abov
Quote:
Any transmission built prior to S# 96JE-06161 has nothing but after that it has the above mentioned updates.
Any transmission starting with S# 97AE-07106 and on has the first set of updates as well as these three o-rings being updated.
Then I suspect that some other parts where changed starting with S# 97H*-00001, but a TSB wasn't generated for those changes, which created the need for the check ball to be added. This last update is actually for a noise shifting OUT of reverse, not shifting into reverse as the two previous ones are.
The ball can be added with the tranny in place. It goes into the valve body itself. The tranny I got is one of the ones that needs this ball and I have heard the noise coming out of reverse a few times.
B3 Brake return spring assembly and low coast modulator compression spring.
A340E 96JR-25596
A340F 96JR-46671
A343F 96JE-06161
"O"-Rings
A340E 97AR-27196
A340F 97AR-27976
A343F 97AE-07106
Old part # New Part # Part Name
35068-30011 35068-50010 Spring sub ass,1st&reverse brake return
90501-08088 90501-08169 Spring Compression for low cast modulator valve
90301-99193 90301-99084 O-ring for outer brake piston
90301-57188 90301-56007 O-ring for inner brake piston
90301-68191 90301-67005 O-ring for inner brake reactive sleeve
Looks like VIN # 04351-60090
TSB breakdown:
A340E 96JR-25596
A340F 96JR-46671
A343F 96JE-06161
"O"-Rings
A340E 97AR-27196
A340F 97AR-27976
A343F 97AE-07106
I have a '95 and am planning on updating the trans and VB.
Are these O-rings for the brake calipers or is it something to do with the transmission or valve body?
Thanks
The "brake" parts discussed above are parts of the transmission, not your vehicle's brake calipers.
