Loud Belts
Louisville, KY
OK, this ranks up with the most basic of basics BUT something I have never thought about until now.
Lately, the belt noise from my engine is terrible. It actually sounds like a bearing has failed in some many places i.e. alternator, tension wheel, AC.
ALL belts are new, from Toyota and cant be more than 5k old (replaced when I did the Timing chain, water pump, oil pump).
Here are some key facts:
It is NOT loud at start up BUT gets there after about 15 minutes.
ALL belt noise goes away IF I go over a puddle i.e. rain is splashed under the engine bay.
ALL belts are set to the right tension.
Oil Pump is new as is the water pump.
I can drop a small cup of water on the tension pulley/belt and the noise completely stops.
It is cold here.
Thoughts?
Have you ever replaced the idler pulley bearing? Use a mechanics stethoscope or a length of tubing in your ear and probe near the idler pulley when it is making noise and I bet you find your culprit. The bearing is cheap and easy to replace.
I have not.
I suppose it is pretty easy to figure out IF that is it. I will just shoot some lubricant down there and see what happens. Should decrease the noise considerably longer than my cup of water.
