Lost second gear
North GA
97 FZJ80 here. The last couple days I noticed that it was holding first gear past 4k rpm and then shifting hard. Otherwise driving fine. Well I realized today is was holding first and then shifting directly to third, skipping second. Weird. So I put it into second and the engine just revs, no forward progress. But back into drive and it will drive ok, going from first to third. I'm also getting a whining noise at parking lot pace, up and down with rpms. No leaks, fluid level is perfect and clean.
Just recently had a shop do a little exhaust work, not sure if they may have bumped something under there, or if I have a problem that is more serious. Haven't had a chance to get under there and look closer, and I might have to just take it to a shop since I need the truck at Thanksgiving. Any ideas?
See what happens if you use the 2nd gear start button, if you haven’t yet.
I’d turn the key to ‘on’, select it & then crank it over, drop it into D 1st & see what happens.
If you can’t catch it that way, then repeat but instead of D go right to 2, so both ways it’s trying to use 2 exclusively.
Do you have a shift kit in it with that turbo, how hard do you run it / miles on it?
Trans rarely go, so at worst @slow95z is somewhere near you and nobody really eats the slushbox.
I'm thinking that the exhaust shop knocked something loose. May be a wiring harness not allowing the shift solenoids to operate properly.
+1
I can get with that, why I stated trying the 2nd start/2nd gear. Flat nothing & time to shimmy under on cardboard.
I really highly doubt it’s internal, but his Safari is a wild card as IDK or have never ridden in one, let alone drove.
But internal as I know slushboxes (again, never been in a failed 80) - the ‘talk back’ awhile before they flat leave you stranded.
Is your overdrive light flashing? This happened to me about a year ago. Ended up being a broken connection in a connector above the starter by the firewall that controlled shift solenoid two
I'll get under there today and look for anything obvious. I do a lot of work and if it's something basic I can usually sort it out, but if something internal went I'll have to see a specialist. I was thinking/hoping for something electrical, since otherwise it does drive just fine. The Safari mods are engine only, and I'm not sure if there's a shift kit on it. Normally shifts smooth and not particularly fast. Downshifts can be a little harsh, but I just figured that was how the box works.
Yesterday we were picking up my birthday/Christmas present, a new toolbox for the garage, and the truck was trying to tell me something. Blew a fuel line and started spraying fuel all over the steering box, which was lovely. Then this transmission issue. I'm still not sure where the whine is coming from, but I guess one problem at a time. The new toolbox will be put to use right away.
All the indicator lights are working like normal, the power and 2nd gear lights work, but of course a 2nd gear start doesn't. It was holding 1st gear for so long, at first I thought the power switch was on somehow, but then I realized it was skipping 2nd completely.
