so your filter stays completely full of oil when the engine is off and you are checking the level?tarbe said:My engine was on Mobil 1 prior to losing oil with the Schaeffer's. Also did a double AutoRx treatment before the switch. No gunk in there...
Even if you did clog a filter, that gunk merely displaced oil out of the filter and into the crankcase.
If the level of a supposedly closed system drops, it is because something came out...not merely went somewhere else in the closed system.
1. a dirty filter is not dry dirt, it is soaked with oil
2. dirty oil also burns more readily
I used Castrol syn in a Mustang GT and it used it right up. Switched to Amsoil and did not see a drop in the oil level. Perhaps a different synthetic for sonoranfun
