went through the same thing. They said i needed a new TB, but Mud said different. All i needed to replace was the TPS.
$300 later and good as new.
Have replaced the TPS...........
Have you considered replacing the APPS (Accelerator Pedal Position Sensor)? The problem in the 98 and 99s was often in the APPS even though the code read "TPS problem".
Quoting myself from the FAQRepeated occurrences are usually solved by the replacement of the APPS (~$270) and sometimes the TPS. (~$70). R&R covered in the FSM SF-35.Toyota upgraded the APPS part# 4 times IRRC, but the TPS part number has been unchanged. The APPS is a more expensive part but if replaced will most likely fix the problem and is still much cheaper than an entire TB.
The TB needs cleaned at the flap as "gunk" build-up can result in CEL codes as is well covered in the FAQ thread on the subject.
Thanks for the insight. Am assuming the APPS is the one where the cable connects to, circular pack- opposite end to TPS?
Dealer says it keeps throwing the TPS fault. Could the APPS be doing this?
Ho do I reset the CEL using the above technique?
Per my MaxEllery manual you can check codes by shorting the TE1 and E1 terminals in your check connector (called DLC1) and then read the flashes of the CEL to read the code.
- do this with engine at operating temp, transmission in neutral,all accessories off and throttle closed
- turn ignition switch to on (not start)
- short TE1 and E1 (or alternatively CG[4] and TC[13] depending on what diagnostic link connector you have)
- now the CEL will flash with the code
- blinks every half second for the first digit then 1.5 second pause second digit, if there is a second code there is a 2.5 second pause then second code, followed by a 4.5 second pause after all codes have been displayed. Then the codes will repeat.
I don't have the chart to convert these codes to a Diagnostic Trouble Code but others on here do.
put APPS on, removed efi fuse, replaced fuse, started car............. still no joy...........
even cleaned throttle body
With the car runnimng, disconnecting the APPS makes no difference.
WHAT'S GOPING ON? sob.............
And, no TE1 and E1 (or alternatively CG[4] and TC[13] ...................... no "plug/wire" where TE1 should be.............
damn, that really sucks. Everything you described pointed to APPS. Did you install yourself?
just done it, wasn't terribly hard to do, 3 screw and it slots in............
if i remember correctly you have to have a tool to align it properly. If it is slightly off it aint gonna work.....
that is if i remember correctly...
