Losing the Splash Shield
Kansastitty
I want to mount a large fuel filter on the frame, and my new motor has an oil cooler, which takes up a little space. Does anyone see any harm in running without the splash shield on the pass side? I am also running a Big Cap electronic diz which is fairly waterproof.
Should I try to just cut out what I need or run without it?
Ed
Kinda what I thought. Thanks, Mike. Hey I still have your Birfs/axles. When is the TAC meeting?
Ed
You'll be OK without it. Your pic shows that your shield has been helpful catching oil from the top. It makes oil changes less messy. Same with the lip along the block/pan seam.
My truck came without the splash shield on that side. Allowed the oil that was leaking out of the oil fill tube base to go directly onto the ground and not collect in the shield. Great advantage!
Dave, since I'm getting rid of mine, do you want it? You purist, you.;)
I might even wash some of the oil off of it.
Ed
BTW, what is that bracket coming off of the battery tray for? The one partially obscured by the hose? I'm taking that prick off, too. Dave? Got one of those?
Ed
Ed
Stock fuel filter/sediment bowl mount.
BTW- have ran the Red truck since '88 without those, and the one under the radiator up front.
Ed, I've got one of each. Splash shield, and fuel filter bracket (do you just do an in-line?)
Here it is with the proper glass-bowl filter assembly.
(I haven't installed my EBay splash shield yet: involves removal of the battery tray, a project I haven't approached yet, because of more vital issues.)
Well color me stoopid. I already made a fuel filter mount out of an old oil filter mount and sourced a fuel filter(spin-on) for it. With the splash pan removed, there should be plenty of room. Guess I could hang a chandelier from the bracket....or remove it.;)
With the big filter, I hope never to change it!
Ed
I remember you mentioning that fuel filter before. Gotta picture? Is the stock fuel pump going to have any trouble drawing through it?
Well, I think the thing ought to be able to pull through it OK, I drilled and tapped the casting for 1/4" npt and drilled the center orofice, too, so the smallest opening ('cept the filter itself) is 1/4". Tell you what.....I won't remove the bracket until I see.
Here is the pic, I did go bling and painted it r-e-d.
Sweet!
Looking at the pictures, I think I can take a piece of 3" flat stock and bolt it to the battery tray, where the stock sediment bowl mount is and bolt my "new" filter to it.
When I engineer it, I will post a pic.
Ed
Where the hell did you get that at????? John Deere!!!! That will definitely catch any foreign objects for a long time for years to come. :) Just like a Land Cruise overkill!!
Naw, it is a remote oil filter mount from an F engine. Keepin' it all Toyota, eh?
Carquest, and others make a fuel filter that spins right on the mount.
I'll report back if it works.:rolleyes:
It is the same type of filter that is on most later FI cars/trucks, but they have a"pusher" pump in the tank, so Dave's point may be well taken.
Ed
