loose wheel bearing causing ABS?
buffalo ny
Hi
my 94s ABS kicks in when I slow down to about the last 5mph it feels like a vibration in the brake pedal and some sliding. I took it to the dealership and they said since it's not throwing any codes they couldn't tell me what's wrong with it. could a loose wheel bearing be the cause? appreciate the info.
cheers.
Hi
cheers.
Find a different mechanic / dealership. If they cannot find an issue with ABS because it didn't throw any codes, then they either have no idea what they're doing or don't want to work on that truck.
Yes, loose wheel bearings CAN cause an ABS issue to trigger. Also check tire pressures.
Yes, a loose wheel bearing can cause weird things like this to happen. Get someone who has experience with these to take a look.
My '97 was doing this and I've done a number of things to improve it, here are a few ideas from my experience, in the order that I did them:
  • removed/cleaned all wheel sensors and made sure that the mating surfaces were clean so that the sensors were as low/close to the tone rings as possible. I don't recall this helping much.
  • cleaned/greased the sockets/connections to the wheel sensors. I don't recall this helping much
  • did an axle service, including new spindle bushings and proper wheel bearing preload/torque, which helped but didn't resolve the issue.
  • did numerous brake fluid flushes which seemed to help for a time but then the problem would return. I don't really understand the flush impacting this and it could have been observational error but it's what I recall.
  • replaced the birfields/cv joints which was a major help
The two items that seemed most relevant for reducing the slow speed brake shudder on my 80 were the axle service and the new birfs, which I did at separate times. It wasn't until I installed new birfs that the shuddering went away. The birfs that were in the truck were OE with 250k miles roughly. They clicked in turns and may have had wear on the bushing surface and the joint itself that allowed the tone rings to move closer/further from the sensor. I also wonder if there was enough slack in the flange to birf interface to contribute somehow?
On some rigs later, long birfields have been installed with earlier shorter flanges. This will allow the birf to move in and out enough to knock off the hub dust cap and to trip your abs, etc.
thanks for your response. my 80 is at 250k so maybe it's time for birfs/CV. how much would that cost do you think?
There are plenty of factors in the cost of CV/birf replacement, DIY vs. paid labor being the largest. Keep in mind that the ABS problem on your rig may not be the CV/birfs. I was surprised when they fixed the ABS issue on my truck and it could just be that I have a weak sensor issue and the new CV/birfs have slightly larger tone rings or something odd like that.
Replacing CV/birfs requires digging pretty deeply into the front axle and if you've not had a recent axle service done it's smart to plan full axle service along with cv replacement. Costs of parts and labor will vary and if you do this yourself it will be way cheaper of course. Folks like Cruiser Outfitters have good quality, often OE, parts kits that can make getting everything you need easier and less expensive.
Going all OE and dealer labor costs could put this total job in the $2k plus range since the OE CV joints are probably $600 or higher each. Non OE CV joints vary in cost but can be less than half of the OE prices. etc. etc. If you run larger tires and wheel hard you may want the non-hardened CV joints as they are less likely to shatter though they wear out faster in our full time 4wd rigs. Hardened CVs, like the OE ones, are best for stockish trucks that see a lot of road miles and where longevity is more important than rock-crawling capability.
I had the same thing happen as I would brake the abs would come on as I was almost to a stop. I removed my abs sensors and found one had a small crack in it. A new harness from the dealership (if I remember right was quite expensive) was the only way I was able to find a new replacement, so I kept looking. Finally found a used sensor through cruiserparts.net. Replaced the sensor only and problem solved.
