Loose Steering........what do I do?
Probably wouldn't be a bad idea to take it in and have the wheels/tires balanced and have it aligned.
How is the power steering fluid level?
Just so you know, there is only 1 adjustment on your Land Cruiser and that is toe-in. Toe-in can be adjusted fairly easily using a DIY method. However, it would be good idea to take it in and have them put it on the alignment machine so you will have all the numbers as a baseline for future changes.
Out of balance tyres shouldn't create the steering issues you described. Check the air in all 4 tyres and make sure you have 4 identical tyres in good condition. Plenty of problems are caused by mis-matched sizes.
-B-
what would I do? stop driving it until you know it's safe for one thing.
Check all the fasteners first. Then go from there.
Is there a lift?
I had the same problem on my 95. Replaced all the tie rods and connecting sleeves, plus the steering damper. Much, much better.
