Loose nuts; NOT knuckle studs...
Utah
So I changed my oil the other day, and as I was checking the knuckle studs with my wrench, A thought occurred to me that I should check the nuts that hold the 3rd member in the front axle. It was leaking, so I figured why not?
Every nut was less than hand tight :eek::eek::eek:
I have never touched those nuts, and it sure scared the $#!^ outta me. I plan to clean off the diff and put some threadlocker on them.
One good thing came out of this, though, my clunk is MUCH lighter now.
Whew...
What could have caused this to happen?
Locktite GOOD.
-Spike
The nuts and studs that hold the 'pumkin' together. The section the differential is in.
-Spike
Can't say that I have seen any bolts in the diff, thought it was all welded, I will have a look tomorrow see what you mean
Hint- look on the pinion side. You don't really think they weld the gears in, do you? :hhmm:
-Spike
Most likely the diff studs are loose also. This happened to me too. Do the double nut routine to tighten the studs.
I've heard of this technique a few times, but it doesn't quite click in my head... Could you explain it?:confused:
Coulda been 248k miles, maybe? :)
Maybe, but still... A lot of guys here have at least that many miles. The nuts shouldn't loosen up by themselves on an untouched 3rd member.
Also, how do you 'know' these are untouched nuts? Everything looks untouched to the eye at a quarter million miles.
Anyhow, good catch and these are a good idea to check for all of us when under for an oil change. I'll be draining/filling my diffs this week and you reminded me to check mine - thanks.
DougM
Thread the first nut onto the stud and don't let it bottom out. Thread the second nut onto the stud and tighten the 2 nuts together using 2 open end wrenches. Now you should be able to tighten the stud by tightening the outer nut.
This may not be easy with the diff in place. There's not a lot of room in there.
