Loose front axle?
Norfolk Virginia
I have been noticing more and more road noise lately almost like the sound a bearing makes when it goes bad, like a rumble and I jacked up the front end of my 97 and neither wheel has play top to bottom or lefty to right, I also did just replace the front bearings 2 years ago but when I spin the drivers side tire I can get almost a quarter revolution before the other tire spins the opposite. also when the slack is taken up by spinning it there is a ping when the wheel seems to engage. I dont have the 2 wheel drive conversion I just have the factory drive flanges. anyone having this same thing happen? is this much slack normal for 200,000 miles?
A "ping" sound would direct me to U-joints first. Does the front pinion seal leak oil? Are you positive it's coming from front end? Is there an accompanying vibration? Any particular speed? Acceleration or deceleration?
the u joints are fine I am thinking there is play in the birfs or perhaps even the front third member. I don't know how to test those separately without disassembling the front end
