Loose Coolant lines
I'm looking for some help with remounting the loose coolant lines in the photo. I believe they are going to the transmission cooler? I'm looking for the part numbers for the mounts?
AI says you have some options:
AI Overview
The primary part numbers for the automatic transmission fluid (ATF) oil cooler lines and hose brackets on a 1996 Toyota Land Cruiser (FZJ80) with the 1FZ-FE engine vary depending on which exact bracket location you need:
[1]🛠️ Line & Tube Bracket (Along the Frame/Block)32909-60160: This is the Transmission Oil Cooler Line Bracket / Union Clamp which secures the main hardlines/tubes running along the side of the engine toward the transmission.
[1, 2]🪟 Transmission Oil Cooler Mounting Brackets (At the Radiator/Cooler)If you are looking for the brackets that physically mount and secure the ATF fluid cooler assembly near the radiator, those are divided by placement:
[1]32913-60170: Cooler Lower Bracket32913-60160: Cooler Upper Bracket (Right side)32913-60140: Cooler Lower Bracket (Left side) [1, 2, 3]
There are two mounts for these forward hard lines. One in the front that mounts to the upper oiI pan and another toward the rear that mounts to the motor mount bracket. I believe they are 32909-60030 and 32909-60020.
There are other mounts on the bellhousing and transmission itself for the rear hard lines. Not sure if you need those as well.
As mentioned above there are also plastic mounts on the fan shroud for the forward soft lines.
AI Overview
Completely wrong based on the picture of what he needs above Ash.
Wow great photo. Thank you so much!
