Looking to tap in to the trailer harness
GrizzlyClint
Hippie Redneck
Idaho
I'll make it short and to the point. Is there a no cut/no splice solution to tie in to the trailer harness so I can use this to power additional turn indicators and brake lights while still allowing the harness to function as normal when I tow?
You could probably use one of those dual adapters, but I am not sure how you are wiring anything up after that without cutting something.
You can get a piggy back connection that is called a 4 way flat y splitter. It basically creates two 4way connections, one of which you can cut off and wire up as you like while still maintaining your original. Got mine from Amazon.
