Looking for mechanic in KC area 80 series
Make sure you get the spark plug tube gaskets and pcv valve gasket while you're at it.
I've done the valve cover, but not the oil pan. I could probably lend a hand one of these days if you can't get anyone to help.
-Andrew
Both oil pans use FIPG sealant instead of gaskets. Be sure to use the Toyota stuff. Also, you'll need an engine hoist because you have to lift the engine about an inch or so to remove the upper pan.
