Anyone know a good machine shop in the Seattle area to turn my flywheel? Got it and the clutch out of my rig this weekend. Big oily mess. Looks like the rear main seal and maybe the oil pan gasket. Both are on order, and should be here soon.
Martian,
there's one other oil leak that you can fix but I think you'd have to remove the bell housing.
It's an oil gallery plug that looks like a small size freezeplug located at about 10:00, the ten o'clock position viewed from rear as in your photo) on the back of the engine block. The plug rusts/corrodes from inside usually resulting in a pinhole leak that will eventually grow. Some people have threaded the hole for a screw in plug but it'd be a big one at, I think it was, 27mm.
at two o'clock is a camshaft plug that sometimes does the same thing. It's visible and looking OK in your photo, but who wants to have to do this job twice?
Other common leaks are the side cover and valve cover but you don't need to be where you are now for those. All of them can contribute to the goo you've found at the back of your engine.
