Longfield Install
After further examination, I have figured that the longer birfs and longfields can be used with free wheel hubs if you get a second grove machined further down the shaft so that it would align with the original shorter birf.
I have had all my componnets apart the past few weeks and have figured that the reason the lockout cap does not fit is because the tapered portion that holds the locking gear hits the circlip on the end of the birf.
If this circlip is at the back next to the gear the birf slides through, then it is fine. I did not have any rubbing on the end of the longer birf with any portion of the lock out cap. The birf actually fits inside the recessed portion fo the cap a good ways.
Now I just need to take it all apart and take my longs to a machine shop to groov another notch for the circlip.
My limited researched has never found a birf fail at the shaft, so I am taking this into my own hands, but I do not feel that the added clip groove will be any different than the other one located further out. I do believe in the Aisin hubs more that having a drive plate or a warn hub.
Again. If you do find the ultra rare long body Aisin hubs, this will work with the longer birfs without any modifications.
Good luck. I will report back with my findings and hopefully pics next week after I get it apart, machined and reinstalled.
