The pics you posted of your 40 are real interesting. They show real close to what I have been slowly putting together in my mind. I would appreciate it if you would answer some questions for me.
First some stats on my 40.
1971, mostly stock, still with the F engine, 3 speed tranny and TC, and close to stock size tires. Manual sag steering. Rear disc brakes. Currently working on moving the alt to pass side so I can mount an Astro remote res power steering pump, and maybe still have room above the pump to eventually mount an air compressor (maybe York). I already have a Scout steering box with the stock pitman arm. I have a 1978 FJ55 with a very badly rusted body to eventually use for donor parts, springs and front disc axle specifically, maybe 4sp tranny.
Plans
The 40 will eventually be a DD for me. I want to go longer wheebase, mostly for onroad manners, but also for wheeling/hunting. I want to do a little bit of lift and a bit bigger tires, but not real extreme. I am trying to do my mods a little at a time to keep from being overwhelmed both financially and with my small amount of time I have to work on it.
Questions
1) Is there a special reason for having such a flat angle on your front shackles? I know that they should not be too vertical, but I was under the impression that they should be about a 45* angle.
2) In the pic of the Scout steering box, is that a stock pitman arm?
2a) Did you box the frame and run the bolts through tubes, or are the mount bolts just threaded into the thick mount plate?
3) You used Ford shock towers, are they forward of the stock location to accommodate the stretched wheelbase, and if so how much?
3a) Do the Ford towers have the factory angle on them or did you need to mod the angle to clear the Scout box?
4) From reading on here I have gotten the impression that stock springs ride better than aftermarket lifted springs. Is this correct?
4a) Is there a special reason for using 55 rear springs both front and rear on your 40?
I am wanting to get the PS done this winter, but I am not sure if I will have time to also move the axle forward (one mod seems to snowball into multiple others).If I mount the steering box to work for the final location of the axle do you forsee any problems? I realize that the angle from the pitman arm to the tie rod will not be ideal.
If you are able to answer my questions I would really appreciate it. My family and I will be leaving Friday morning about 9:00 A.M. for the weekend so it may be better to PM me or send an e-mail to --- termitedon(at)dswebnet.com
Thanks!!!
MUD U. -- the University of Construction
Here goes:
1) The shackles are indeed done this way purposely. A couple of different reasons. For starters I wanted to use longer springs and went into it hoping to avoid moving the shackle hangers. But it is not just laziness. This leads to the second reason.
A straight line from spring eye to spring eye gets longer as the spring flattens and shorter as it droops. That's why the shackles are there in the first place. Your shackle has to be long enough and located such that when the spring is at its longest the shackle does not run out of room (top out against the frame). You also want it long enough and located such that at max droop of the spring the shackle is either short of forming a straight line with the end of the spring, or just barely reaching that point. Failing to achieve the former will result in damaged springs. Failure to achieve the latter will reduce suspension droop.
It gets more complicated though. If your shackle was vertical when the suspension was sitting at ride height, the horizontal displacement when the shackle moved in a short arc would be much larger than the vertical displacement. Nothing wrong with that per se. But... the shalloer the angle of the shackle the larger the vertical displacement compared to the horizontal. We allput a lot of effort into increasing the potntial for our suspension to move upwards and downwards. Sonce the amount of horizontal displacement is dictated by the spring itself, a shackle at a shallower angle will give you more vertical movement than one at a steeper angle.
Additionally with equal angles, the difference in horizontal and vertical movement is accentuated by a longer shackle over a shorter one.
So... My long shackles at a shallow angle give me a softer ride with more suspension travel than shorter ones at a more conventional angle.
I trod a fine line in sizing these shackles. I did not want any more lift than unavoidable. But I also had to make sure that the shackles were long enough to let the springs go completely flat without topping out and hitting the frame. Of course because of the shallow angle, extra length of the shackle does not add as much lift as it would with a steeper angle.
One downside of this setup on the front end of the rig is that the suspension has a bit more side to side flex than it would with a factory setup. It's not bad, but you can defimitely feel the difference on a win ding mountain road when compared to a stock rig. But then the boggers make a lot more difference. It's a small compromise.
2) That is a stock Scout pitman arm. Sort of. I shortened it to match the travel at the end of the pitman arm to the travel at the end of the knuckle arm. I also put a dog leg in it so that a straight line through both ends of the pitman arm is at an angle to match the angle of the knuckle arm. This is important if your drag link connects to the knuckle arm rather than the tirerod (like the stock steering does). When you connect front pitman to knuckle arm the angles have to match or you will have more turns of the steering wheel in one direction than the other. Even when everything else is correctly centered. The side with more turns will respond slower but be stronger (more leverage). You may actually run out of travel in the steering box before you reach the limit of the steering knuckle.
2a) The plate is welded to the frame. Sized so that the welds tie it to the top and bottom faces of the rail, not just the outer face. The frame at that point is fully boxed and additionally the front cross memebr ties in at that spot too. The plate (3/4 inch) is threaded and the mopunting bolts are secured to the plate. This is plenty strong. I have mounted a few Scout and FJ60 boxes this way. Works great. Clean and simple.
3) The Ford towers are mounted to line up with the fore shifted axle. Another approach which can be used instead of or in conjunction with the location of the shock tower is to turn the lower shock mount/tab around. This gains you a couple to 3 inches. It also helps keep the passenger side shock clear of any double knucle arm (The aqualue arm is sensitive to shock clearnace whn the axle mount is stock for example). On the driver side it may ease you shcok clearance from the steering box.
3a) The shock mounts on this rig have not been altered. They will be soon, particularly the driver side. I ned to cut than bend the backwards to introduce more angle to the shocks. They are close enough to vertical as to make no difference. The shocks are the limiting factor in my suspension tavel. Adding some angle to the shocks will give me more suspension travel for the saem amount of shock travel.
4) Yes. In general lift springs have higher spring rates. Also a spring with more arch will give a heared ride than a spring that is identicla except for the arch. And many of the aftermarket springs are too short by varying amounts which resilts in a steeper shackle angle.
4a) FJ55 rear springs are longer than '40 springs. The axles is almost centered on the '55 spring. This gives you an almost identical axle location as reversed '40 springs. but with an additional 6 inches or so beyond that. This produces a spring that flexes more. Significantly more suspension travel with the '55 rears than with the stock '40 springs.
Mounting the steering box in it's final location will ceate a less than ideal angle for the draglink, but it should be perfectly doable 'til you finsh the rest of the mods. but I've never done it this way, so check it allout carefully, don't take my word for it.
Mark...
