Long Travel Shock
Austin, Tx
I know this has been revisited probably numerous times but I am lost in the vast amount of threads discussing them. I am running L's. So far they have been ok, they are just too short. I need something with more extension. I have been browsing multiple shock manufactures websites and hard to find what I am looking for. I would prefer to not be a pioneer and use something someone else has already used and know they work. I have 5" comp springs in the front and j's in the rear. The J's are now sold so I am going to put in the 5" comp springs. That means 2" spacers in the front now I presume. Well I constantly am limited in the rear by my shocks. I am sure I am not the first person or the last. Basically what are you guys with 6" of lift that actually wheel your trucks hard running. I know Ebag was using Pro Comps but he isn't near as big as me. I am running 315's now, 37's-39's in the future. I would keep the J's except that now I have 2 half sets sitting here collecting dust. Anyone have any ideas? I don't mind changing mounts if there is a simple way to do it. I don't want to spent 500$ a shock on some crazy Fox remote reservoir, and I don't know enough about valving, etc to make an informed decision. I would like to keep the price fairly cheap, I don't mind running cheap shocks being my truck gets less than 5,000 miles a year. In a perfect world I can sell the L's and fund the new ones. :) Any help would greatly be appreciated.
D
Get eye adapters and run some Bilstein 7100's.
Keep in mind that your too short shocks are tied into too short springs, so you'll be dropping your springs well off the tower by using a shock setup designed for down travel.
You can also simply space down the rear shock mount and keep the L shocks if you like how they work except for the lack of down travel.
I have used Doetsch before, great shock for the money. Real popular with the Baja, Pre-Runner and rock crawling crowds! Some models you can get 18" of travel, that's 44" extended! They will costume valve the shocks for your application. I say it's worth a look!
Mono-Tube Shock Rebuildable
I am running BDS shocks. The rear I am using a 12 inch travel eye to eye shock and I made a new upper mounting bracket for the tops of the shocks. The mounts are very similar to what someone on here made I think his name is Ben I don't remeber his screen name.
I have about 4.5 inches of up travel and quite a bit of down travel.
I know you are running 5 inches of lift so a 14 inch shock might work well.
The BDS shocks are not that expensive they are the 5000 series and are designed for an F350 Super duty and was told that the valving is very close to that of the an 80.
This is the part that's so confusing to me. Why produce a spring that provides 6" of lift and only be a 2" longer spring to achieve it? Do any of the manufacturers make a 6" taller spring that's nice and soft, so it flexes well and won't drop out of the perch?
Chris
I think that it is not the spring but the length of the shock that will allow the spring to drop in the perch.
When I flex out the rear of my rig the springs do not fully drop but they are loose on the perch.
That is why I messed around with the shock size and the mounts so that the spring would not become totally losse and flop around on the perch.
I have seem rigs flex and the spring is completly unseated from the top perch and I do not think that it is a good thing.
Having good flex in the rear is great but to much in my opinion does not keep the suspension balanced since the front of an 80 does not flex all that great.
Just my 2 cents
This is the part that's so confusing to me. Why produce a spring that provides 6" of lift and only be a 2" longer spring to achieve it? Does any of the manufacturers do it right and make a 6" taller spring that's nice and soft, so it flexes well and won't drop out of the perch?
Chris
You have a 6000+ lb truck that does not like to sit on a 6" soft spring. It is pretty easy to build a floppy jallopy but they do not wheel so good. BTDT. For stability on the 80 you are better off to take a shorter spring and retain the top and bottom so you have some negative spring rate that will act like a limiter vs just unloading all the way.
You can get a Fox 2.0 resi for $185 ea thru downsouthmotorsports.com. They will valve it for you based on what the rig weighs, weight on each axle, tire size, etc. A 12" shock will be plenty long using eye adapters for a 6" lift. You will need to lower your bumpstops or add progressive poly stops like i did. Search "fox 2.0's are on" for my thread.
That's definitely a good point...my only thought is to control the unloading with a anti-rock type swaybar instead of losing travel by running shorter shocks and springs. I've also experienced that with the softer spring rates, the unloading doesn't happen as much, because there's substantially less upward force to the vehicle. Not trying to argue Christo...you obviously are much more of an expert on this than me...I guess it's personal preference, I suppose.
Chris
Chris
Because that's what fits in stock mounts is the answert that's been given in the past. Slee is working on some remote resivour shocks that mount in stock mounts, but they're very pricey - not rediculous considering what they are, but pricey compared to 'normal' shocks.
Most 6" springs they make really stiff to compensate for the height to control sway, rather than controling sway through other means.
as far as longer shocks
I'm running 14" RS9000XL's front and rear on custom mounts. You could probably get away with just adapters in the rear if you ran a 4" bumpstop, but I'm set up with a little over 2" bumpstop (I think, memory is weak). I really need to open up my top mounts a little more as those XL's are just such a huge body.
Here is some other stuff I found when I was searching before I did mine
https://forum.ih8mud.com/80-series-tech/158408-rear-shock-adapter-extender.html
I suggested a FAQ on it, but I don't think it ever got added
https://forum.ih8mud.com/80-series-tech/163065-faq-shock-mounts.html
I looked into front hoops when doing mine
https://forum.ih8mud.com/80-series-tech/161100-front-shock-hoop-opinions.html
In the end I built my own (like I do most things) - I have a 1" body lift, so that helps clear the master cylinder.
https://forum.ih8mud.com/80-series-tech/162864-extended-shock-towers-14-rancho-9000xls.html
As far as shocks, the XL's are a nice shock for $100 a piece. If I wanted to go cheap (and I might to replace a damaged one) I'd go pro-comp ES9000, I think it's the best shock under $50 you can get.
A 14" travel shock works well with 6" of lift from what I've researched. Because the axle travels in an arc, 14" is really quite a lot more than it sounds.
Pro Comp offers some longer shocks, but once you get past 16" you're going to have an awful hard time fitting them in without dropping the bump stops ridiculous amounts.
The Bilsteins are nice, but pricey.
You may want to try several different shocks until you get something that's tuned they way you like. Personally I find the OME's to be far too soft for my taste.
I have 6 inch spring lift, 1 inch spacers, and 1 inch body lift. I use Bilstein 7100 shocks with 14" travel with the remote reservoir. Valving is 275/78. I just broke one due to contact with a tree. Other than that they have worked great.
out of curiosity, why the 7100s and not a 5150? seems the valving is very similar...and i find the 255/70 5125s i have out back are just adequate, a bit on the soft side compared to the oem replacement yellow tube HDs. is the rebuildable factor worth the premium?
got a p/n for these? what coils are you running...and hows the ride?
I will get p/n for the BDS shocks off my rig today and a picture of the upper mount that I made for them.
I am running FOR first gen 4 inch lift springs so they are not the progressive rate sprimgs so the ride can be a little rough especially with running 40 psi in the tires on rough roads.
If I run 35 psi it is not as bad.
The shocks seem to ride fine to me.
It is such a fine line to find a good ride quality with the weight of these rigs.
To soft and the rig seems to hanldle like crap.
Also the reason I have the FOR 1st gen springs is because Frankie gave me a smokn deal on some springs he had left over after he changed the design.
You answered your own question. You can custom valve 7100's for higher damping rates. The guys here that have gone this way have gone with 360/100 or heavier. May not be worth it, though, cost wise for most people.
