Long Term storage
BOZ
Valdez, AK
I may be leaving the country for a year or more and was wondering about long term storage. If I park it for a year what could be expected to be toast when I start it up again. I thought of selling but its the best ride I have ever had and hate the idea of parting with it.
Please post up thoughts
From personal experience, I don't believe you will have a problem. When my 80 was 3 years old, I parked it for a year in Vermont. I backed it into a mini storage unit, disconnected the battery, and walked away from it for one year. Almost one year to the day later, I returned, reconnected the battery, and the vehicle fired right up. You may consider adding the appropriate product to the fuel to make sure you don't have any problems in that area. Otherwise, if you like the vehicle, I would say keep it. Leaving it for a year shouldn't be a problem.
I stored a different rig for over a year and it started right up after I put a new battery in it; ran a little rough until I got some fresh gasoline in the tank. Storage in a dry garage is better than outside where the birds will poop on it which will eat into the paint, change the oil and add that gas additive (forget the name) for long term storage to the gas tank, consider flushing the radiator then add fresh Toyota Red coolant, air up the tires to the max pressure, and once it's parked remove the battery. You could change all the gear oil and ATF also if they were real old. Don't get rid of it, it will survive. My 2 cents.
More vehicle damage when stored comes from rodents than the vehicle aging. However, gasoline with ethanol in it absorbs water more readily than normal gasoline and it has changed the recommendations for storage. I'm not going to give a definitive answer on the fuel but have read regarding my boat that ethanol's appearance in fuels means the old recommendation of storing the fuel tank full has changed to storing it empty. I have not fully researched this and my brain cannot believe a full tank would not be best, but so be it.
So, I'd have an anti-rodent strategy, put the truck indoors, fill the tank and put whatever additive is appropriate for the type of fuel in your area (ethanol/non ethanol) and thoroughly clean the interior to prevent mold or mildew growth. Personally, I'd also jack it up and put the axles on wood blocks to protect the tires. Fresh fluids are always a solid recommendation as certainly old motor oil with high acid content and unburnt blowby fuel in it would not be good for the engine. Before you start it up, leave a note of anything you need to do (connect battery, etc) and remind yourself to look over the engine bay for nests or things that indicate a closer look at the wiring would be good before energizing the electrics.
DougM
Stabil is the brand name of one fuel additive that I've used. Should be easy to find. Can't say how it works in an 80, but gas treated with it that I've used a year or more later in various small engines and vehicles seem to run just fine on gas treated with it.
Yes, avoid any gas in the tank with ethanol added to it because it definitely absorbs water.
