LONG OVERDUE transfer vacuum valve conversion writeup
...personally I'd rather put 80 series lockers on and use the Downey kit to convert them from electric to cable :D
I have only had a 60 for about a year and know very little about 80 series parts going into a 60 - is that a big / expensive job ??
Oz vs US ? Everything is FF rear here, will the 80 centres fit into our 60 diffs ?
With slight modification to the axle housing, the 80 series rear locker will bolt into a 60/62 FF rear, and directly bolt into the front IIRC. It's just a matter of finding the complete carrier with gearset and locker.
No worries.
Hmmm.
Spook50 - can I ask why you prefer to convert the electric locker to a cable ? Not reliable ?
The electric part can and will eventually fail. It's far more reliable than alot of stuff out there thanks to being a Toyota part, but that doesn't make it invincible. Get it all gunked up or submerge it for a while and you'll dramatically shorten its life. Converting to a cable actuator will eliminate those problems. I'd rather have more stuff mechanical than electrical just because of a longer service life.
Hence the inspiration for my vacuum valve mod :D
Mike, all I had was the valve, two 1/8 NPT brass filters, a 1/8 NPT right angle hose nipple and two 1/8 NPT straight hose nipples. And about 15' or so of 1/8" ID vacuum line. Very easy project. I also converted the 4WD light back to using the factory indicator light, so you don't have to worry about any wiring mods at all for it now.
Alternate valve vendor
Converting an FJ62’s 4WD Vacuum Shift from Electric to Manual​
By Dan Moeller a.k.a. Spook50​
After 18 years and 217K miles, the electric solenoids that control my transfer case’s ability to shift into (and out of) 4WD had finally failed. Any electrical part will do this eventually, so why pay $300-$400 for a new part that will fail again (albeit most likely not for several more years)?
To understand what I’m talking about, let me first explain how an FJ62’s transfer case works. To shift between high (1:1 ratio) and low (2:276 ratio) gears, the case is shifted by a stick. However, instead of using that same stick or even a 2nd stick to shift between 2WD and 4WD, the case relies on a vacuum actuated diaphragm. The position of this diaphragm dictates whether the case is in 2WD or 4WD, regardless of what gear it’s in. The vacuum to this diaphragm is controlled by two solenoids mounted on the firewall, just inboard of the windshield wiper motor.
There you are you little buggers...
When the top solenoid is active (linking the manifold vacuum source to the appropriate vacuum hose connected to the transfer case), vacuum forces the diaphragm to shift the transfer case into 4WD, and the bottom, when active, does the same thing, causing it to shift into 2WD. The electric drive selection allows for 4WD high range to be activated with the push of a button. This setup is convenient, but inherently flawed. There is also a switch installed on the transfer case that will automatically activate the 4WD solenoid when the case is shifted into low range. The stock configuration allows for three gearing options, excluding neutral; 2WD high range, 4WD high range, and 4WD low range. Due to the automatic drive selection, 2WD low range is unavailable.
As with any electrical part, these solenoids will fail eventually. With the high price of a replacement part, a common practice is to find an idle up solenoid from older Toyota Camrys and Celicas. The parts are nearly identical, with the only difference being the style of electrical plug. These solenoids are approximately $30 new from a Toyota dealership. Much more favorable than a new pair of transfer solenoids that cost upwards of ten times that amount. When my original solenoids failed I debated on converting to the other solenoids, but with the parts being electrical, I wanted something that would go a lot longer before failing.
For over a year I looked into my other available options. I could spend $600 for a used transfer case off an FJ60, which uses a stick for both 2WD/4WD and high/low gears. With an easy modification to the linkage (or with the fabrication of a twin stick setup), this would give me the wanted option of low range 2WD. That was more work and money than I want to invest at this point. I could take the opportunity to split my case and rebuild it, while installing the nose cone from an FJ60’s case to gain the ability to manually shift between 2WD and 4WD, but again, that would cost the price and work of rebuilding plus the necessary parts from an FJ60’s case. Lastly, I could install a manually actuated vacuum control valve in place of my vacuum solenoids. I decided on this method, as a manually actuated valve would easily last the life of the truck itself.
The next problem was sourcing one that would fit my needs. I called around to many local hose and hydraulic shops and finally found one that caters specifically to industrial companies. I had to finagle a bit to get them to order the part, but the one I found was perfect for my application. The valve is a 5-way Norgren pneumatic valve, P/N X3044322. The ports are 1/8 NPT pipe thread, so I bought three 1/8 NPT with 1/8” barbed nipples (one of which is a right angle fitting for hose routing issues), and two 1/8 NPT brass air filters. Since the supply shop was able to get these as well, I just ordered everything together.
The valve as it is shipped. Port 1 is for the vacuum source, 2 and 4 go to the hard lines leading to the transfer case, and 3 and 5 are vent ports.
Since I have no need to pull the fittings off the valve, ever, I just raw dogged the installation (ie: no Teflon tape). Brass is “self sealing” for lack of a better way to put it, which makes it great for vacuum systems and pressurized gasses. In the next pic you’ll notice that ports 4 and 5 on the valve have the brass filters installed. This may not be entirely necessary, but I decided to err on the safe side, since when one vacuum line (2 or 4) is linked to the source (5), the other is vented to open air. This action allows the diaphragm in the transfer case to shift freely when you select a port on the valve. For example: with the switch on one position, the source port (1) will be connected to an output port (let’s say 2). Also in this position, port 4 will be vented via port 5. In the other position, 1 will be connected to 4 and 2 will be vented via 3.
All the fittings installed. The valve is now ready to be installed in the truck and have the lines plumbed.
For plumbing the vacuum lines, I bought some 1/8” ID vacuum hose and fed the vacuum source from the intake manifold (you can tell which vacuum line is for what just by looking at how they’re routed on the firewall. Just trace them from the solenoids) to port 1 (the right angle fitting) on the valve. Ports 2 and 4 were connected to the vertical hard lines that lead down to the transfer case. It doesn’t matter which of the two hard lines ports 2 and 4 are connected to. Just make sure you know which position is for 4WD and which is for 2WD when you have it all set up. For this reason I made sure to keep the functionality of my 4WD indicator light.
To get the hoses through the firewall without drilling, there’s a large rubber grommet just outboard of where the hard A/C lines pass through the firewall. It stretches easily so I punched a small hole in it next to where the wiring bundle passes through it and fed all three vacuum lines through. Make sure you keep track of which hose is for the vacuum source though. That’s the important one!
Here you can see my new hose routing and the now unused (and dangling) solenoid connectors. I’ve since cut the wire as far back into the harness as I could, since I’ll never need it again. The half-assed wiring in the pic is from my aftermarket ignition, which has since been cleaned up.
The hoses all hooked up to the valve (with the toggle lever set to the 2WD position in my case). You’ll have to jockey it into place to get the fittings and lines through that hole in the dash. Now whenever I pull the dash I just undo the nut on the toggle and remove the plate that the valve is mounted to.
The valve all installed and ready to go. The labeling is a laser etched black metallic decal that was cut to fit over the blank plates. I did up the designs in Adobe Illustrator and took them to a sign maker in Spokane Valley. As you can tell, I used the two blank plates just above my ashtray.
Works flawlessly. I blacked out the lens for the factory 4WD light and rerouted the wiring to a red 12V light I picked up at Radioshack, just so I could have an indicator near the switch. It’s very easy to see even in direct sunlight when I have 4WD engaged.
It’s been almost three years now since I did this mod and it still works perfectly. The install went so well that most people who ride in my truck and aren’t familiar with 62s think this is the stock setup from Toyota. I would not be surprised if this valve lasts the life of the truck. Finally, just for ****s and grins, here is a pic of my complete dash, with a little more laser etching just to add to the styling…
Im getting ready to do this conversion and Ive had to go to another vendor for the valve, as the company listed in this post wouldnt respond. Anyhow, ive found an identical one through STC (Sizto Tech Corporation) and the model number is MPV522. I think I paid around $40 shipping and all. They also have all the fittings etc. Ill post once Ive finished it and let yall know how it comes out.
Mine is still working like a champ. Once I install the H55 (which has a manual converted tcase with one of Georg's twin stick kits) I'll sell my vacuum kit, with the hoses labelled so it can be installed easily. Will post up in classifieds once I'm able to sell it.
Thanks for the write up and linkages, everybody.
I don't have a cruiser yet, but I do have the 4bd1T engine to go in it :D
That 2 lo option is huge when backing a trailer, IMO.
Shifting to low automatically engages 4WD BECAUSE of the solenoids. The stick shifter only shifts between high range and low range. Because of this, there's a switch somewhere in the mechanism that sends power to the 4WD solenoid whenever the tcase is shifted into low range. Since my mod eliminates the solenoids, you now have to shift into (and out of) 4WD with the valve. Since this eliminates the automatic engagement of 4WD when shifting into low range, you now have access to low range 2WD.
HPD, that was why I did up the designs the way I did. I wanted something that could pass for a factory stock appearance. I think I got it pretty close :D
Old post but was wondering if this mod ELIMINATES the electrical switch in/on the transfer case? Does one leave it there or remove the wiring or?
No it doesn't eliminate the switch, leave it there.
Correct. Switch and all actual wiring stay put. Only thing removed is the two solenoids from the firewall.
With the switches on the transfer case left in place but the wiring cut off/removed (sort of like a FJ60 case now), there will be no problem as they are not in use anymore? The firewall solenoid removal is understood but will the old transfer case existing wiring interfere in any way? I am having a hell of a time with all my dash gauges/fuse blowing whenever I manually shift the transfer into low..... This setup sounds like the perfect way to eliminate all the funky wiring and switches.
I wouldn't cut the wires ........ But if you're concerned that they might be causing the issue, then disconnect the sub-harness. The connectors for it are at the firewall near the starter.
Georg @ Valley Hybrids
On the FJ62 transfer case, there are 3 indicator switches ON the case... The lower one (#3 in the photo)
appears to be the 4wd indicator switch that lights up on the dash, but what are the top 2 ?? In this photo they are labeled #1 and #2
I just went ahead and ordered a Festo Electric Solenoid (spring return) to accomplish almost the same thing but without running vacuum lines into the dash. I needed to do it this way as space is limited in my 40 (2H swap). This will use an electric switch in dash and the 5/2 solenoid valve will mount on the firewall.
This is how it was listed for anyone interested.
FESTO MEH-5/2-1/8-B SOLENOID VALVE W/ MEH-3-12VDC COIL
for future ref, the other 2 switches are for the Nuetral warning lamp, and the 4X4 warning lamp. the LO range or XFER switch is what controls the solenoid(s). for those who want to do the 2 LO mod, just unplug the LO range switch- you loose the XFEr warning, but you gain the 2 LO- UNLESS you use Spookys manual valve(good idea BTW;))- then you can have 2 lo and KEEP the XFER warning...
