The longer rear seats are a USA seat, from 08/73 and earlier...
You will need to modify how they attach, as your truck should have a stock roll bar, and the longer seat will not just " bolt up " like the smaller seats did.
Yep to Poser's, in stock configuration the long seats are flush to the sides of the truck and top with no room for the OEM rollbar behind them. They use the sidewall as part of their mounting support.
If you want to lose your rollbar it could be done although you'd need to use nutserts in the side channels where OEM has captured nuts.
This is all about the stock long seat in stock configuration. If you want to install some kind of long seat in order to carry wide people or many smaller ones use your imagination to install whatever you can find that will fit in the space available.
i am probably better off adding the con-ferr rear seat that flips forward and is removable.........gotta keep the rollbar or wifey will say no more for you!
