locktite knuckle stud?
Bay Area, CA
I was looking at the knuckle stud upgrade thread and I saw the kit included locktite red - I realized I didn't locktite mine in at all. How critical do you think that is? mine's not all buttoned up yet, so it would not ba a major pain to pull the arms, studs, clean the holes, locktite - well, jeeze maybe it woudl be a pain - but easier now than later, when the steering and body's back on.
This year's Rubithon was the year for knuckle studs...
I saw three stud repairs this year, each one a little different.
simple snap:
Easily replaced by removing snapped stud and installing replacement.
stripped stud, on knuckle side:
Drill out your knuckle stud-hole, and tap and install helicoil.
several stripped studs, on knuckle side:
Weld arm to knuckle.
(None of the rigs/repairs mentioned above ran locktite)
In the different repairs, Locktite would have turned the "simple snap" into a PITA.
As Andrew mentioned, Locktite (especially Red) is not needed if installed properly.
IMO, locktite them in there....I have the studs on my spare knuckle tack welded from the inside to ensure they don't come free.
I retorque my knuckles every single morning....always....IMO, the huge majority of knuckle stud issues is lack of torque....79 ftlbs is correct, BTW. (yes, I keep my torque wrench in the tow rig....) If you run harder trails or 35"+ tires, it's foolish not to....
Mine are not Locktited but i did grab them w/ a Vice-Grip before I put the arms on and tightened them into their holes. I also check the nuts every morning as well. Its cheap insurance.
Kinda a catch 22 - sure the studs broke but it's probably because they came loose - If they weren't loose then they wouldn't break. I locktite'd mine after the front knuckle rebuild - i use red locktite on everything though, should buy it by the barrell around our shop :D
What about locktite on the conewasher and nut? anyone brave enought to try that too?
I have seen 4 different rigs on 2 separate wheeling trips in the last month break knuckle studs. Two of them sheared off all 4 studs, one broke 2 studs, and the other broke 3 studs. They all broke due to not being tight.
R.K.
That will happen every time....
Hy steer simply amplifies this issue.
Red locktite on studs to knuckles, and nuts to studs.
Check often.
Good luck!
-Steve
