Locking in 3rd Row Seats
Austin,TX
New member here with a recent '99 LC purchase. I'm having issues locking the 3rd row seats into the floor (note: I found the other thread referencing getting the seats back in, which isn't the issue). For the life of my I can't figure out how to get them to lock onto the floorboard and the owners manual isn't all that helpful (move it forward and backward). Any tips or suggestions on this subject or a redirect to a previous thread that I may have missed?
Appreciate the help for a newbie.
Are the swing out locking mechanisms at least aligned with/hitting the latches on the floor?
Yep, everything aligns as it should. Wasn't sure if it was a faulty latch or if there is some mechanism that latches it (i.e. turning a handle, pushing a button, etc)
If that handle on the seat (that slides it forward and back) isn’t helping then you may have a busted latch. But that seems odd—neither side is latching to the floor properly?
Is the floor mat in the way? That happened to me yesterday.
I have a similar issue with one of mine, but it was from dropping it when taking out of storage. The two things that I have found that make it actually latch is first I slam it down and also make sure the little rod that attaches to the handle that allows you to slide the seat is fully disengaged.
Im just gonna say it, you did remove the plastic plugs from the floor latch area and put them in their holders under the seats before closing? So many people don't know what these are for but normally they stay fitted on the bottom on the seats where people don't tend to notice them and never make it to the floor, so I doubt this is your problem.
And if you have to say it, I have to laugh. But yes, plastic latch covers are removed. I am going to try and lubricate the seat portion of the latch as recommended and see if that helps.
Have they ever worked since you’ve had the truck? Take a picture of how they’re lining up and a couple pictures of the latch mechanism when it’s sitting on top of floor and one being held right above the floor. That may help someone here to see if there’s an issue with the latch.
Thanks! I’ve had the LC for just over a week, so this is the first time I’ve tried putting the seats down. I started the thread to ensure there wasn’t some sort of trick to get them to latch that I was missing in plain site. If I can’t get it latched after some of the other suggestions I’ll post pics as you’ve suggested.
I know you said everything lines up but just to be safe: the only time I've had a problem getting the seats to latch was because they needed to be slid forward or back just the smallest amount . Grab the lever sitting toward the inner side of the seat from the back and it can slide the whole unit on the outer frame rail. Short of that, it might be a bad mechanism. Have you tried holding the release lever while pushing down?
I did try and slide it back and forth slightly, to no avail. It could be a bad mechanism, which isn’t a huge deal as I’ll just take them out for now (don’t need them, they just rattled too much in the stowed position for my liking).
Going to toy around with it after the holiday and see how it goes.
When I bought my truck I got one of my seats loose and it took me half an hour to figure out how to get it back in. First, you have to make sure you have the seat slid forward or back to the right spot. Then pull the other handle that unlocks the mechanism to allow the seat to lock into place.
I think I would see if another Austin member would be willing to have you swing by their place and let them give it a shot. There may be just the smallest thing you're overlooking, I've never heard of a seat mechanism fail but its possible. I feel like its going to be one of those moments like, "You gotta pull this while pushing here" scenarios.
