locking axle upgrade - interchange
I'm looking into replacing the rear axle in my 92 fj80. I started trying to find an axle with an electric locker and have located a few. Will any from a 93 or newer bolt up? If I get one with disc brakes, I assume I'll have to swap the master to match, any problems there? Does $900 for the rear with locker sound fair? It's local and in decent shape. Thanks from an 80 newbe, SD
That's not unreasonable. You may be able to pull the check valve in the rear circuit of the master cylinder. Otherwise, get non-ABS master cylinder from SOR or other.
Where did you find an axle with lockers?
Trying to do some research for a friend with a '92 FJ80 as well. As ESDE asks, is a newer ('93+) axle pretty much a direct bolt-up into a '92 aside from the brakes?
I've never worked on the newer stuff and my friend knows next to nothing about his vehicle.
The other option would be to get an ARB for his existing axle.
Any thoughts?
