Are the front and rear locker dash lights to blink or stay on solid? If u were to have them locked on drive pavement the steering would be difficult, r we talking like no power steering difficult or just a little more difficult?
Is it a faulty switch? Why do I hear the solenoid when I engage the CDL? If I dont engage the CDL first then I dont hear the solenoids when I just turn the locker switch. If I just turn the locker switch I dont hear the solenoid and the lights just blink.
The CDL needs to be engaged for the lockers to engage, therefore no "click" with just the locker switch.
... I guess what i'm trying to explain is that you must be on a low traction surface and make each wheel spin at different rates until the splines line up in the diff. This could also be done by doing circles on a dirt/gravel surface. I would keep exercising them and you might get lucky. HTH (hope this helps)![]()
If the goal is to test operation, you are not sure about your method, the most definitive way is: Jack up the axle in question, turn on the locker and turn one of the wheels, it should lock right away.
