Locker switch in dash removal
Trouble shooting my rear locker. It's not unlocking intermittently. Anyways. Anyone know how to remove the dial on the dash. I would rather not trial and error with flat head screwdrivers.
I would pull the whole bezel piece off in one first. Lower the bottom knee bezel first, four screws. Then pop out the switch bezel but you will have to disconnect each pigtail snaking your hang behind.
The rear locker locks up fine. However I had trouble unlocking it when I left on the last wheeling trip in Cali. I had to turn off the CDL and drive in the dirt a bit to get it unlocked.
The actuators have all been rebuilt and worked flawlessly up until then. The last trip down to the beach I ran I couldn't get it unlocked for awhile.
I'm not hearing the relays click when I unlock it and jacked up the axle to verify the tires are spinning in the same direction. I'm also not getting a voltage signal at the pigtail on pins 2&3 when I turn the dial to unlock.
I'm wanting to check the switch and work from there. I also need to jump the actuator to verify the unlock and make sure the it's also good there.
After a lot of trouble shooting it seems to be the locker switch on dash. I can lock and unlock front locker no problem. However the rear locker to unlock I have to wiggle the switch near the off position then I hear the relays click.
