- Joined
- Nov 30, 2005
- Threads
- 11
- Messages
- 46
Locker conversion / axle housing bent question?
I recently purchased a pair of locking axles for my 1996 lc. I had been looking for complete axles as well as just actuators and parts seperately for awhile but never found anything that was reasonable and close by. Car-parts is full of listings but getting someone that will actually go look at the part to tell you it's condition or whether it truly is the locker setup(the first I drove two hours to get turned out to be non locking
) is slim to none on the probable scale. $1000-$1250 per axle assembly and nearly as much for the parts seperately had kept me from the conversion.
On ebay I saw that Jardco had a front and rear assembly that had come from a vehicle in Japan with apx 87,000miles that had been rolled. They stated that the rear housing was bent on the drivers side but they thought the front housing was straight with only damage to a front rotor, but they would not gurantee it. The pics showed nice clean parts, some paint to clean up for import but overall alot of shiny bolt heads and clean threads. It came with both the driveshafts, wiring harnesses from the actuators, and the shocks.
So I'm thinking that if the rear is bent who cares...I'll mod my stock rear and use the diff parts etc and I'll have tons of spares like both ends of the axles, cables, lines, fittings, rotors, calipers etc..
Then I'll use the complete front if straight (keep your fingers crossed). If it's bent I'll again have all the parts needed to convert and I'll have two bent housings to grind on to see if I'm capable of the welding required up front. Or I could use the parts and hope to find an empty locking front housing. I paid $1195 for the pair so I'll either have done the mod cheaply if it's straight or pay a little more for the mod if it's not.
The above is my attempt to rationalize the purchase of potentially bent housings..lol
Well they shipped faster than I was ready for and and been sitting at the local business I sent them to since friday.
I want to ask your suggestions on how to best verify the housing is straight. I have read the threads I found on mud as well as other sites and the methods seem crude at best. The rear is obviously bent and the front has a bracket thats bent as well. I sure would hate to put the front under the truck only to find it exhibiting bad behavior. I can turn both the assemblies by hand from the center fairly easily.
I've included some pics of what I picked up today.
ouch....what happened there?
And a shameless plug for another constant work in progress and my parts hauler since I was taking pics....
