Locked front, open rear mod?
nakman
addict.
Supporting Vendor
Broomfield, Colorado
Website
www.gamiviti.com
Anyone ever done a mod to their rear locker wiring harness to disable it, while still having the front locked? That is, presuming that's all there is to it.. :confused:
We were on a run today trying to break trail through the snow, and the subject came up about how handy it would be to have the option of locked in front, open in back. Ever back up in snow/ice on a side angle and your ass keeps slipping down the hill? But you can't open up all the way or you'd go no where.. locked front/open rear would be ideal for this scenario... I can be open/open and open/locked, I want to be locked/open.
Shirley someone's done this? :grinpimp:
99.99% definitely possible.
You could first try by just powering the front lock signal wire at the switch - jumper power to front only - however the difflock ECU may not like the fact the front has been engaged without the rear.
It would depend on the logic written into the ECU, if the failsafe program is.....lock the front anyway as this bloke has a U/S switch and may be stuck in a bog and we better give him the front lock to get him out even though the rear lock selcetion of the switch has failed..... then it will work with a very simple rear lock bypass switch.
But the ECU program may be...... something is wrong, front lock can't be selected without rear, we will flash the diff lock lights in unison so he takes it to the dealer to fix it..... and this would not work.
However with a miniture 4PDT switch and a few wires one could possibly trick the ECU into thinking the rear is already selected and locked, and this would be the new rear lock bypass switch. A bit more of a hassle the second way, but definitely doable I believe! My 0.02
Actually if the second scenario is the case, a mod to Christo's interior winch control board would probably work, however, I don't think there would be enough takers to bother having the circuit board reworked. I think a mini toggle switch may do this job, although there may bit of muckig around with the wiring for those who want it.
If you have dual ARB lockers it is VERY easy. One jumper does it.
