Locked Diffs in 4hi
Can I lock the Diffs in 4hi? I did it on my driveway and rolled forward about 5 feet but don't know if the diffs were actually locked while the lights were on.
If the dif lights went from flashing to solid they are on.
The reason I needed to know if they locked in 4hi is for mud runs. Most 4x4s with selectable lockers limit you to only being able to lock them in 4lo.
That is the default for 80's - if you add a CDL switch and do the "pin 7 mod", you can take total control of the ABS on/off when center/trans case locks despite weather in hi or lo range, and diffs in sequence.
The ABS kicks out whenever the trans case is locked - that stays constant. What changes is you can lock the case in high, or leave it unlocked in lo.
(I use this a lot here in WA state, esp when coming down from Mount Baker on snowpack roads, also when launch / retrieve boat at the launch, either algae covered concrete skids, or undeveloped dirt/sand launches.)
Both cases I like my case & diffs open w/ ABS, but using the lo gear.
IDK if you have a locker 80, but the rotary switch means the rear needs be selected to be locked before you can go locked up front. Open> rear > fr & rr
All that said, you seem like you intend to flat flog it, so just for reference - a rear ARB locker is stouter compared to shaft-binding your factory locker on the splines...but that's all you. I've owned both & I wouldn't want bigger than 315's / 35" on factory locks, just my experience & where/how I use my 80.
