Lock-Right Problem
Philly PA
I got a Lock-Right from a friend, he took it out of his 40. Got it all in no problem but when I spin me wheels (it is still on stand with the diff cover open) the teeth on the driver skip off the teeth on the coupler. I have the thrust washers on, the all the stop pins are pused over into the bias springs. All it takes is me turing one wheel by hand to make the teeth skip over each other. His 40 is a few years older than mine, I have an 8/73 with 3 speed on the floor. Anyone have any ideas?
Mine will ratchet with both wheels off the ground. Sounds really bad with the cover off and no 90weight in there. Also, the slack between the teeth is normal at a quarter turn. You may be fine assuming all the parts are in there and shimmed correctly.
Agreed. It sounds like it's working correctly.
While it's 'skipping' the teeth, try turning the other wheel just a bit. It should lock both up. I recommend only doing this with the tranny in neutral.
yep, it sounds like it's normal. Your friend didn't give you the instruction sheets? As I recall, part of the after installation checking includes making sure that it does exactly what you're describing.
Drop it on the ground and take it for a spin. I was v nervous about this myself, but I've had no problems, no ratcheting, no squeaking. I do get a surprising amount of understeer at high speeds (60mph +) when I floor it at the apex of a turn.... ;-)
Take her for a spin....you'll know if it's working right then. mine ratcheted correctly but then slipped popped and made all sorts of noises while driving...very bad slipping and I was withing the spec. range...so i think it was just wore out...
