Alright guys, 1993 Surf LN130 Auto, 4WD won't engage. I know it's not the ADD system, I deleted that via manually sliding the collar to locked and securing it with a hose clamp, then looping the vacuum line to itself on the actuator to keep out gunk, and the ADD position sensor is plugged in and functional on the front of the diff. I am fairly certain it's an electrical issue with the electric transfer motor on the rear of the transfer case. I have tested that my 4WD switch functions properly with a multimeter, the 4WD ECU is getting power and ground, and no fuses are blown. The engagement sensor on the top of the Transfer motor has power and ground to it, so it's functioning. The only issue I need help with is the 5 pin connector that tells the motor to activate. I tested all the wires coming OFF of the chassis, female side, and the results were:
White/Black - Ground
Black/Yellow - Ground
Green/Orange - Ground
Pink/Green - No Reading. Neither +12V nor Ground
Yellow/Red - No Reading. Neither +12V nor Ground
Is there supposed to be +12V to either of those two wires? If yes, then I need to know where the source is to find my fault, if no, and they are merely pulse/signal wires, then my Transfer motor is fried. Solid assumption?
I have already looked at each wiring diagram on the Surf tech site for my answer to no avail. If anyone could provide some input, I'd appreciate it very much.
![IMG_0101[1].webp IMG_0101[1].webp](https://forum.ih8mud.com/data/attachments/714/714085-e1807bb1bbe98f49b10856ff97bbc797.jpg?hash=fs6NE0zjCg)
![IMG_0102[1].webp IMG_0102[1].webp](https://forum.ih8mud.com/data/attachments/714/714086-085978e7b6b05102fdd2dc6ec738edd7.jpg?hash=MjWI70hyXK)
![IMG_0103[1].webp IMG_0103[1].webp](https://forum.ih8mud.com/data/attachments/714/714087-c53721943d0b72fbd4a838ad29786282.jpg?hash=BXK0cMT3sL)
![IMG_0104[1].webp IMG_0104[1].webp](https://forum.ih8mud.com/data/attachments/714/714088-5db9a84a10c6131e7841e8c52b9d0197.jpg?hash=3qAQ8ltz0H)
![IMG_0105[1].webp IMG_0105[1].webp](https://forum.ih8mud.com/data/attachments/714/714089-08ae02ae8584d019291aeead5352d4e9.jpg?hash=g-Cz4H34ev)
