Any Mods to fit the 285/75?
Yep - The lift/spacers/KDSS relo and cutting out the plastic that was rubbing.Any Mods to fit the 285/75?
I don't have the relo kit on yet... it just barely touches the bolt and rubs on both arms at full lock. I'm going with the Anderson full kit to save the bushings and keep the system as close to spec as possible. Actually, got the last one he hadin stock this morning!Looks so good!
How is the kdss bolt rub prior to the kdss relo kit with the 285/75's?
Are you getting the slee kdss bracket or the full Anderson kit that moves the sway bar end links outside of the LCA?
I did the 1" since I don't plan on changing the front bumper.I'm leaning the same way, I need to order his full relo kit.
Keep us updated once you have it on. Did you get his 1" or 1.5" kit?
Looking forward to seeing everything together!
What steering wheel did you get and do you have a part number? I just picked up a 2016 and will need the steering wheel upgrade in the near-term. Thanks.Been quietly collecting parts and planning out the project in one swoop.
Westcot Spacer lift installed front and rear
Firestone airbags in the rear
Powder-coated the BBS wheels
1in bora spacers
Wrapped them in 285/75/18...
Also, ripped out the scratched-up steering wheel for a fresh one.
To-do -
Order the KDSS relo kit,
Get the OTT tune
Go on an adventure
Yep - The lift/spacers/KDSS relo and cutting out the plastic that was rubbing. >>>>> How thick of spacer?
