I have a 1992 landcruiser. I'm now replacing water pump. Something still blocks water pump from getting out on water inlet side after taking PS Idler Pully with bracket out. Any idea?
thanks
thanks
You shouldn't need to remove the wheel well skirt or the smog pump. I didn't remove those items when I did mine. It was a horrible job, but definitely doable.
the water pump is cake.
Have you done a water pump on a 3FE while it's in the truck? I replaced everything while I was there because I never want to go through that again.
Yes, 3 times, all were in the truck.
Congratulations on getting the job done! Wasn't that bad now was it?
