little help on the 12v system
About a month ago I changed the fusable link in my
late 85 Fj60 (with orig.74K miles on it...Yes 74K), it solved all my problems that I was expereincing
then last week the alternator stopped charging the battery....Again...so:
I changed the main ground connection to the battery - nothing
Changed the battery - nothing
Changed the 2 year old mean green alternator and guess what?
Still no charge to the system.
It will start with the fresh battery but only run with the choke on/ no fans work/ no interior lights etc.....
I did get a voltage regulator sent up here but have yet to find in on my cruiser. Anyone want to spare me the inspection and tell me where that little bastard is hiding
Keep in mind it is about 8 degrees, wind blowing 35 with two feet of snow in my driveway so all of this has been...a little difficult
Other than this little ordeal, the thing has been great!
Any suggestions would be much appreicated.
I can't wait to get back out in the dark and make it work......
On my 85 FJ60 the regulator is integrated into the alternator. It's looks like a little PC board that bolts onto the outside. Since you don't have a stock alternator, I don't know where your regulator is..
later...
I did a little checking. It looks like the 55A alternator has an integrated regulator and the 40 and 45A alternators have a separate regulator. I still don't know where it is installed, but it looks like it might plug into the back of the alternator, so it shouldn't be too far away.
I would pull the fusible link and inspect it and then measure the resistance on each of the 3 leads.
Also check all the fuses with a meter not just a looking at them.
So you had a MG alternator in there and you changed it out with another one? Maybe you got a back alternator. Where did you get it?
Thanks
Hi Kevin,
It looks like the culprit is a dead short. Both Alternators and Batteries are fine. I have a spare now.
The new fuseable link was toasted again. I think I am going to put in a marine fuse block with a spray sheild ( I happen to have one from one of my boats) and do away with the 40 dollar fuseable link.
I have yet to find the short but I am going to bring the truck inside to thaw and put a light down in there so I can work on it properly.
Trying to do simple repairs in this environment sucks. So I will heat her up and find the short and be done with it.
Any idea what the amperage draw of the red wire in the fuseable link is?
I am think of starting with 15 amps and working my way up until it does not fry under full load.
I would think from the size of that red wire it is likley a 25 or 30 fuse wire.
Anyway, thanks for the help!!
